| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 65 New Guy | | New Guy Joined: Nov 2009 Posts: 65 | Was anyone tried or thought about trying to make the outer trims out of door outer trims ?
New but in an Old Way !!!
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Not me, but thinking about this, you may be able to use pieces of them for patches. | | | | | Joined: Nov 2009 Posts: 65 New Guy | | New Guy Joined: Nov 2009 Posts: 65 | I've played with my old door trims and it seems a right door trim (dt) fit the middle window. straight side of the dt against the back side of the window. A right dt again would need to be used again but upside down with straight side against the front side of the window. Because if a left dt was used the top portion does not reach across because of the curve.
ps the front side of the window is a lil narrower the the back side so it would need to be notched.
| | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | J-Kat, I took mine off and trashed them. I am putting solid glass in the sides. My rings were bad. I know where some are though. [email protected].
Sully
| | | | | Joined: Nov 2009 Posts: 65 New Guy | | New Guy Joined: Nov 2009 Posts: 65 | I talked to the guy, he said nothing right know but check back with him. Thanks for the lead and new connection,,,, wheres he out of anyways ?
| | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Oklahoma. Keep looking. I would also go to the swap meet here on stovebolt and post a "parts wanted"
Merry Christmas
Sully
| | | | | Joined: May 2007 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 34 | Hey guys i've got one trim ring bad out of the six. i do have two extra ones for the doors and it looks like it will take both of them to fix the one ring. The bad part is the the rings are so thin that it's going to be hard not to melt them while welding them up.. cross your fingers for me.. | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | theres a guy out here that was gonna tig weld patches on his trim using front door pieces. ill check if he ever did and try to get pics | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | nope sorry,, i went by earlier and still nothing had been done.. ill keep checking up on the progress | | | | | Joined: May 2007 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 34 | Thanks for checking... i'm going to cut and weld the front one as a test piece so i'll know if i'm using the right amount of heat... they are just so thin...... | | |
