4 members (thekid1950, Peggy M, RoadsScholar, Hanks custodian), 164 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
12/6/09
Well Gentlemen, this is the start to my 1949 3600 build. Superfly contacted me out of left field to get this truck. I was seriously going to pass until he said he could haul it. The cab I had was already being fit with patch panels (and needed to be re-done). This was completely cheaper than fixing the floor.
We start with the clip from the 3800 I got from my brother. This, the title, long running boards, doors and battery cover are all I have left from the original deal.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project012.jpg
Here is the new truck in my shop
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project001.jpg
There is some real nice color on the firewall. It cleaned up pretty good with some cleaner wax.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project002.jpg
My thought is, this truck came from the factory as a flat bed or inteded that way. The short running boards and the dark green paint on the stake pockets lead me to believe the bed was added later. I have the full length 3800 boards, I think I'm going to shorten them to have a 2 piece running board.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project006.jpg
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project005.jpg
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project008.jpg
I ended up taking alot of rat crap and nesting out. Under the seat was packed and a layer over the floorboards.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/100_0319.jpg
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/100_0326.jpg
Here it is all cleaned up.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project004.jpg
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project007.jpg
Plans are real basic for this rig.
292 inline 6
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project010.jpg
'91 full size Chevy 5 speed
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project009.jpg
Scott Danforth's cross member kit.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/shop042.jpg
Not going to try and reinvent the AD pickup. I want it to be built safe, minimal cost and frills. Manual brakes, manual rack & pinion and S-10 rear axle. Trying to keep the original column and shifter in place are a high priority.
12/8/09
Mondays progress. Disassembly. Steering gear is off, column saved (may need to look for a better wheel), shifter off and saved, drivers door off, 2 more clutch head screwdrivers ordered.
Tuesday before work I got the passenger door off. Leaving the hinge on the door made it a little dicey trying to get the top one out. Resting the engine hoist in the window track helped keep it stable while unbolting. But it was all back work when she got loose. Picked up my other 2 clutch screwdrivers on the way to work. Looks like I will have a date with the shovel after work, frickin' snow.
12/10/09
Wednesday:
After blowing a bunch of snow out of the driveway, I got down to the shop for a little bit before work. Out of the 4 clutch drivers I picked up none of them fit what I was trying to do, get the floor panel off from over the transmission.
Solution, get a good straight screwdriver that fits snug in the clutch while keeping downward pressure try to turn. If it doesn't feel like it wants to turn use a crescent wrench or vice grip for added leverage.
The panel came off and I was able to go to work knowing something was accomplished.
After work I picked up Jaime who was doing a trucking run through my town. We did more bench building than work but did get the roof popped back out and looking smooth.
12/13/09
Sunday brought major progress.
The motor, transmission and front suspension are all out.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project014.jpg
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project015.jpg
Now to get the brackets stripped off to ready the frame for the SD AD IFS crossmember.
12/18/09
Thursday: I met with the welder and got a good price. I will do all the fitment and he will just have to weld. He really liked the kit and thinks it will be easier than the Hiedt's front he did for another guy.
I got all the bracketry off the passenger side frame rail and sanded it down.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project016.jpg
Between the red lines is really only needed for prep. I sanded inside the rail and underneath too.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project018.jpg
The bell housing crossmember is in the way a little bit. It will be removed after the cross member is welded in. This is the part that is in the way.
Here it is removed from the other side.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project019.jpg
A bracket needs to be welded inside the frame rail for support. Scott gives very detailed measurements of where it needs to be. After studying the install manual, I'll show you the dummy way. Again on the passenger frame rail, (right side is front) the red circle shows the hole the bracket needs to be placed over. The large hole is where the brake line came out.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project021.jpg
Looking inside the rail, (left is front) the bend goes to the front.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project022.jpg
Next, I will prep the other side. Then fit the boxing plates.
12/20/09
Sunday: Got more accomplished.
Started getting things roughed in. The front of the frame needs a little notch. It is measured from the front edge of the frame. At first I was how the hell?? But, here is how. Use a welding magnet and fish the tape through the frame.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project025.jpg
Then your masking tape marks the notch.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project024.jpg
Cut out.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project023.jpg
My boxing plates ended up being a little long (which is way better than short). I set them up in the frame located where they should end, then set up for a 3 inch hole. (forgot to grab camera)
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project026.jpg
Then made finishing cut on the bandsaw.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project027.jpg
Test fit with my son the hand model. I wonder what he thinks of this?
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project029.jpg
For the hell of it we slid the crossmember up there.
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project031.jpg
http://i432.photobucket.com/albums/qq42/todd55021/1949%20Chevrolet%20pu/project030.jpg
Next up is more grinding, fitting and getting the welder to come in.
Todd,
Good looking build. Thanks for posting.
Scott
Lookin' good Todd! thumbs_up
More pix on Flickr.
looks good do any bolters have scotts crossmember in their truck and on the road
1949 SUBURBAN
Not yet, however many are close to being finished both on the Stovebolt and on the HAMB.
Hey Todd Isnt Superfly A GREAT guy
Merry Xmas Next year i am not getting you Nothing.
Hurry up so we can do mine.
Hey i have a shop i can use now to.
Jaime
I'll get the sled dogs ready for the treck. But you can start without me. I'll be all brandy'd up when I get there, if I don't take a wrong turn.
looks like a real nice fit Todd. What length springs are you using? i also am putting one of Scotts kits in my 3100.I notched my frame an 1 1/2" to set the truck down a little more.
Chuck
Dunebuggy55
Here is a site listing all the springs
http://jeffd.50megs.com/Moog_Spring_Page.htm
Thats good to know Scott. My springs are 12" free heigth but i dont know what rate they are.I will have to wait until i get everything installed and see what its like.
Dunebuggy55
your springs may have taken a set. I know when I did my S-10 a few years back, the stock springs were almost 2" shorter than the replacments I got from the FLAPS. They were about $35 each.
Chuck, didnt forget about your template for the 1.5" drop with the 3" rake. We have been busy at work and I was in meetings all week.
No problem Scott, I decided i better wait till the front is done before I do the rear.as soon as you can get me the cross member it would be appreciated. Thanks
Dunebuggy55
