5 members (G508, mick53, Peggy M, TIM ZINDLER, 1 invisible), 101 guests, and 5 robots.
Topics128,269
Posts1,058,403
Members48,485
Apprentice
Apprentice
Gas tank has just been cleaned,from old varnished,under a dollar a gallon gas.Got a new sending unit,before I hook it all up,how do I check the line to the fuel pump(engine is a 250 6cyl 70's Olds)for gunk?If I need to use compressed air is it sufficient?Can the lines be taken off and cleaned or dipped in a "hot tank"?I have a 53 3600 I'm using for parts,hard lines included,with slightly rusted innards.Thanks again as always.I learn something new & fun on this site everyday! thumbs_up
Joseph&Amy in East Oregon. "There's no such thing as a normal life.There's just life.".. Doc Holliday in Tombstone
[IMG]http://photobucket.com/our513100pickup
Hard lines are cheap, replace 'em.
Bill Burmeister
Yep, replace them now and you won't have to do it on the side of the road later!
Joe
You might consider a fuel pump prefilter too (between tank and pump) along with carb fuel filter.
Drew
