1 members (Paul Mullen), 99 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
Where can I find a solenoid for a 57 3 speed tran with overdrive? Is it different from a starter solenoid? I have called 3 shops and noone seens to know where I can go.
yes it's quite different - not reproduced, any NOS disappeared years ago, good luck finding good used
They show up on e-bay fairly often. Randy Rundel carries manuals, kickdown switches, overdrive relays and wiring diagrams for the Borg-Warner overdrive tranny. Maybe he has some leads
Fifth Avenue Parts Counter
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
2 Offline
You might check with some transmission rebuild shops that have been in business sence the 50s or 60s. They could have some used spares in there stash. Hope this helps.
A headlamp relay can also be used if you can't
find an original unit. I used a Standard/Bluestreak #LR-32 and it works perfectly. I also added a switch to deactivate the o/d when not in use.
Bill Burmeister
I can help you out with the OD solenoid and whatever you need to set up your OD. I'm in Seal Beach, CA. Fred 562-598-9308
OverDrive Inc.-P.O. box 173 Portage, OH 43451.
I don't have a phone number or web address for them in my reference material. They also do
conversions for torque tube drivetrains.
Bill Burmeister
