| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Hey guys. Im getting ready to pull my engine and install my auto trans and wanted to see if anyone had any tips or new some problems I may run into. Truck is a 61 3/4 ton w/283. I will be fabricating new side engine mounts. I know that I need the vacuem control switch for the lockup converter. Any tips on which one would be best would be great. I think I need to cut out the std trans crossmember and I know I have to make a new one for my auto and shorten the drive shaft. I am unsure about how the starter and flexplate are going to work out. I am planing to bring the engine forward a little bit. Any tips would be great. thanks | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I put a TransGo NoYoYo kit in a 700R4. It came with a check ball and valve that would still let the convertor function properly even it there was a failure with the vacuum control. I would highly recomend this kit. It made the 700 a totally different transmission.
| | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Thanks for the tips guys. I will let you know how it goes. | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Hey, I have the tranny out and I was wondering if its worth anything. Im not sure what it is yet. It needs some cleaning first but its a 4 speed with granny gear and has the trans break and hydrolic clutch. It came out of a 61 3/4 ton | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | The rock crawler guys love that trans. Find an off-road website with a swap meet forum, and you won't have any problem selling it. E Pay might be another option. Check this one out: http://cgi.ebay.com/ebaymotors/1955...ck_Parts_Accessories?hash=item2a02f87d16Jerry
