2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | Hello all. I have a 1939 Chevy Master Deluxe with the Town and Country horns, that work a LITTLE bit. When I put fire to them they make a sound sort of like a cross between a soft squack and a boop. Is there a set way to test them, and/or repair them? Thanks, Mike | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | First thing I'd do is pull the cover & blow them out good. Inspect the diaphragms where they touch the electromagnets for corrosion. Beyond that I'd have to look in Hemmings for a rebuilder. Someone else may have more info.
| | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | | | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | Woogeroo: Thanks for the site, and Tiny: thanks for the advice! Mike | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | I went through this a little while back..... First off testing them with a battery charger doesn't work. Not enough Amps.
I believe that there are some contacts in there that could be sanded with some emery cloth to help improve contact. I'm not sure if yours work on the same principle as mine.
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
