8 members (BarryP, NorCal52Suburban, Hanks custodian, Bill Hanlon, rfs56trk, Donf, Frank50, Gazz),
122
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 4 New Guy | | New Guy Joined: Nov 2009 Posts: 4 | working on puting a TCI mustang II airride suspension on a 53 chevy P.U. want to keep 235, but the oil pan sits to low and power rack hits oil pan. Added a 1/2 inch riser to front motor mount, but still not enough clearance. Any suggestiond? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome to the Stovebolt pages. You only need to post in one forum. Double posting won't get quicker answers. Don't get impatient. It's not an instant answer board. Someone has probably had the same problem. You just need to wait for him to come around. | | | | | Joined: Nov 2009 Posts: 4 New Guy | | New Guy Joined: Nov 2009 Posts: 4 | sorry Cletis, wasn't sure which forum was most fitted for my post. | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Smokey, I've heard they won't fit with any of the aftermarket cross members a few times but don't remember their being a definitive. I was running a M2 Car cross member in my 53 1/2 ton and it worked just fine, don't know how the aftermarket one's differ. Did TCI say it would work? I'd start with them. I know it's been discussed here in the past in the HiPo section but can't find it yet searching. Mongo | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | start by using a manual non power rack and raise the motor you can notch the x member if needed. my friend did one on his panel truck it just takes more work to use the six | | | | | Joined: Jan 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 24 | I have a mustang bench from JW rod garage in my 54 with 235/t5 set up no mods or moving the engine needed.http://s13.photobucket.com/albums/a260/UPSrodder/Truck%20pics/ photobucket | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | jw rod garage mii do not mount high in the frame | | | | | Joined: Jan 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 24 | The top hats of the MII are not above the frame as in the case of some of the other manufacturers. This allows the clearance needed for the 235 engine. You do sacrifice a couple of inches of drop in the overall height of the front end but that can be made up by cutting down the coil springs. If you are looking to slam it on the ground, then you may want to go to an air ride system. I plan on driving my truck to work every day during the fair weather months, so I didn't want go the air bag route. | | |
