3 members (klhansen, TUTS 59, 1 invisible),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,192 Posts1,057,355 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | got the motor from a frend 4 my truck i think its like a 70 d's year ? thanks
48 3 window truck 63 caddi 73 jeep rock racer
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Find the casting numbers on the block and cylinder head then do a search or post them here.
Drew
| | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | on the block 3921968 [gm] head 4435f12 i think , and the distbitor i in the front thanks
| | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | i did a search and found nothing help please
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It comes up as a '64-'76 engine, and can be either a 230 or 250. The list shows both Chevrolet and Oldsmobile applications. What's the serial number? It'll be the one stamped on the machined pad next to the distributor.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | top row f0521bf bottom row 18w345456 thank you
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | We're getting closer. Need to find a date code with the year. I come up with 2 years that the BF code was used, '68 and '69, El Camino (possibly Chevelle and Camaro, too) with manual trans. If it's a '68, it's a 230. In '69, the code was used for a 250. Not sure where you would find the casting date on that block, but if it's anything like the 216/235/261, it may be near the starter.
Bill Burmeister | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Pull a spark plug and look at the tops of the pistons. The 230 piston is flat top, the 250 (if stock) has a dish.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
