5 members (moparguy, klhansen, Ridgeback, Tinker5, 1 invisible), 167 guests, and 0 robots.
Topics128,195
Posts1,057,370
Members48,469
got the motor from a frend 4 my truck i think its like a 70 d's year ? thanks
48 3 window truck
63 caddi
73 jeep rock racer
Find the casting numbers on the block and cylinder head then do a search or post them here.
Drew
on the block 3921968 [gm] head 4435f12 i think , and the distbitor i in the front thanks
48 3 window truck
63 caddi
73 jeep rock racer
i did a search and found nothing help please
48 3 window truck
63 caddi
73 jeep rock racer
It comes up as a '64-'76 engine, and can be either a 230 or 250. The list shows both Chevrolet and Oldsmobile applications.
What's the serial number? It'll be the one stamped on the machined pad next to the distributor.
Bill Burmeister
top row f0521bf bottom row 18w345456 thank you
48 3 window truck
63 caddi
73 jeep rock racer
ttt
48 3 window truck
63 caddi
73 jeep rock racer
We're getting closer. Need to find a date code with the year. I come up with 2 years that the BF code was used, '68 and '69, El Camino (possibly Chevelle and Camaro, too) with manual trans. If it's a '68, it's a 230. In '69, the code was used for a 250. Not sure where you would find the casting date on that block, but if it's anything like the 216/235/261, it may be near the starter.
Bill Burmeister
Pull a spark plug and look at the tops of the pistons. The 230 piston is flat top, the 250 (if stock) has a dish.
Larry
I don't own a vehicle that isn't old enough to drink.
