5 members (klhansen, Peggy M, Hanks custodian, dt235sd, Otto Skorzeny), 88 guests, and 2 robots.
Topics128,052
Posts1,055,726
#601545 12/16/2009 12:32 AM
I've never had a working throttle cable or the right linkages in any of my old trucks.
There is an extra arm on the accelerator pedal linkage that may have something to do with it? There must have been a clamp similar to the choke cable clamp as well.
It's a 283 w/ Rochester 2-jet as found, but originally an inline 6.
Sometimes you got to leave 'em like you found 'em.
3B Offline
Hy KD Kibbe, the throttle linkage for a 1958 V8 Chev truck [55B-59] was all rods and no cables, and is totally different from the throttle pedal out to the carb, from the rods used on the 6 cylinder engines. You used to be able to buy all the stuff as a kit, from various suppliers.
3B Offline
Hy KD Kibbe, American Classic Truck Parts [which sponsors this site] has the V8 carb linkage kit I posted about, their p/n is TLK5V8 - $49.00, hope that helps.
3B - sounds like KD's looking for the hand throttle cable ... setup should be shown in the assembly manual, and the cable itself w/ knob will be available from the vendors
It's also likely that none of the linkage or the throttle cable are compatable with the carb that is presently on the truck. If someone cobbled some linkage together it can be replaced by the correct linkage as 3B mentioned. You should be able to fabricate a bracket to attach the throttle cable if you really need it. You can increase the engine speed with the choke for cold operation which makes the throttle cable redundant.
Fred
