1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 48 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 48 | I've never had a working throttle cable or the right linkages in any of my old trucks. There is an extra arm on the accelerator pedal linkage that may have something to do with it? There must have been a clamp similar to the choke cable clamp as well. It's a 283 w/ Rochester 2-jet as found, but originally an inline 6.
Sometimes you got to leave 'em like you found 'em.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy KD Kibbe, the throttle linkage for a 1958 V8 Chev truck [55B-59] was all rods and no cables, and is totally different from the throttle pedal out to the carb, from the rods used on the 6 cylinder engines. You used to be able to buy all the stuff as a kit, from various suppliers.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy KD Kibbe, American Classic Truck Parts [which sponsors this site] has the V8 carb linkage kit I posted about, their p/n is TLK5V8 - $49.00, hope that helps. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 3B - sounds like KD's looking for the hand throttle cable ... setup should be shown in the assembly manual, and the cable itself w/ knob will be available from the vendors | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It's also likely that none of the linkage or the throttle cable are compatable with the carb that is presently on the truck. If someone cobbled some linkage together it can be replaced by the correct linkage as 3B mentioned. You should be able to fabricate a bracket to attach the throttle cable if you really need it. You can increase the engine speed with the choke for cold operation which makes the throttle cable redundant. Fred
