4 members (Ponchogl, GRNHydra, TPR57C, stlcardinalsguy), 143 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#60283 05/09/2006 1:18 PM
Junior Member
Junior Member
Hello;
I've purchased a '51 half-ton Chevy pickup with a '56 235 pickup engine in it. My cooling fan is too close to my radiator. I assume the water pump shaft has already been shortened as the pulley lines up with the generator pulley. I found I had to bend the fan blades to keep them from hitting anything and now I'm concerned that they are not balanced and may cause engine damage. Do I need to move my radiator forward to correct this problem ?
John Morris
Washington, Vt
John,my brother drives a(forgive him)55 ford customline that he put a 351w in,he had clearence problems with a few things and the fan to radiator was one of them. He bent his fan blades and has been driving it for over a year and has had no problems with vibrations,noises or cooling. But on the other hand we've done some pretty shade tree things around here that has had some bad results and some that has not had bad results but it just was'nt the right way to do it,so I would definetly get more info on that sitution.
1949 Styleline Special
1972 K5 Blazer
John, The fix that's been around for years is a water pump with a shortened shaft and flat type pulley. You can make one or buy one from most truck vendors on this site. Getting the correct fan is another issue. I had to use a whittled down fan which was ok until the hot summer months. So I added an electric fan in front of the radiator.
1946 1/2-Ton Chevy
Or you can buy a pump adapter and use the old pump from the 216 and have corect clearence and a pump you don't have to special order. With the adapter the fan will be in the right place and you can use your old fan blade with out altering it. You can buy the adapters from several of the old truck suppliers or on ebay.
ttodd, remind me to give you a discount on your next adaptor plate for all your posts recommending my adaptor plate. Dave
My Blog
#60288 05/10/2006 12:50 PM
Junior Member
Junior Member
Thanks guys.
I have had a 235 in my 49 for more than 10 years and the fan is very close to the rad. So close that I cannot get a fan belt by. I worry that I am too close but with a good set of motor mounts and no hot rodding of it I am hoping it will be okay. I cannot say I recommend having it that way and also do not recommend moving the rad foreward.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
