0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60283 05/09/2006 1:18 PM | Joined: May 2006 Posts: 14 Junior Member | | Junior Member Joined: May 2006 Posts: 14 | Hello;
I've purchased a '51 half-ton Chevy pickup with a '56 235 pickup engine in it. My cooling fan is too close to my radiator. I assume the water pump shaft has already been shortened as the pulley lines up with the generator pulley. I found I had to bend the fan blades to keep them from hitting anything and now I'm concerned that they are not balanced and may cause engine damage. Do I need to move my radiator forward to correct this problem ?
Thanks John Morris Washington, Vt | | |
#60284 05/09/2006 5:19 PM | Joined: Dec 2005 Posts: 112 Member | | Member Joined: Dec 2005 Posts: 112 | John,my brother drives a(forgive him)55 ford customline that he put a 351w in,he had clearence problems with a few things and the fan to radiator was one of them. He bent his fan blades and has been driving it for over a year and has had no problems with vibrations,noises or cooling. But on the other hand we've done some pretty shade tree things around here that has had some bad results and some that has not had bad results but it just was'nt the right way to do it,so I would definetly get more info on that sitution.
1949 Styleline Special 1972 K5 Blazer
#60285 05/09/2006 9:00 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | John, The fix that's been around for years is a water pump with a shortened shaft and flat type pulley. You can make one or buy one from most truck vendors on this site. Getting the correct fan is another issue. I had to use a whittled down fan which was ok until the hot summer months. So I added an electric fan in front of the radiator. | | |
#60286 05/10/2006 2:52 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Or you can buy a pump adapter and use the old pump from the 216 and have corect clearence and a pump you don't have to special order. With the adapter the fan will be in the right place and you can use your old fan blade with out altering it. You can buy the adapters from several of the old truck suppliers or on ebay. | | |
#60287 05/10/2006 3:41 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | ttodd, remind me to give you a discount on your next adaptor plate for all your posts recommending my adaptor plate. Dave
See the USA in your vintage Chevrolet! My Blog | | |
#60288 05/10/2006 12:50 PM | Joined: May 2006 Posts: 14 Junior Member | | Junior Member Joined: May 2006 Posts: 14 | | | |
#60289 05/13/2006 7:21 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have had a 235 in my 49 for more than 10 years and the fan is very close to the rad. So close that I cannot get a fan belt by. I worry that I am too close but with a good set of motor mounts and no hot rodding of it I am hoping it will be okay. I cannot say I recommend having it that way and also do not recommend moving the rad foreward. | | |
