6 members (Gdads51, 52Carl, Otto Skorzeny, dwreills, 55shaker, 32Fordpuchoptop), 70 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#60252 05/09/2006 1:17 AM
excuse my question boys,but i just biought a 3/4 ton chev, very original,nothing was done to this beast except for very small 8 bolt chrome rims, top speed is about 50 miles an hour,i can start in third gear with out any trouble at all!!!
what gearing is the rear end ,,is it possible to change just the gears to make this thing go at least 60 at a lower rpm?..i want to keep it loking stock,to include the engine and transmision.
#60253 05/09/2006 1:31 AM
do a search on Eaton and find more than you will care to read about swapping in a 67-72 4.10 pumpkin
#60254 05/09/2006 8:27 PM
but mine is a 52?
#60255 05/09/2006 8:54 PM
52 pick-up,
maybe I can be a little more clear... do a search on "Eaton" and you will find plenty of information about how to swap a later (67-72) rear carrier with 4.10 gears into your 52 axle housing thus giving you a higher top end.
With 31 inch tall tires and a 4.10 rear cruising 60 shouldn't be a problem
you probably have a 4.56 maybe a 5.14 rear. My 53 1 ton has 4.88s for some reason.
hope that helps.
#60256 05/09/2006 9:20 PM
It's probably 4.55:1 if it's stock.
If it's a 4 speed, I'm a little surprised that you can start out in third. (Very surprised if it's a 3 speed). IIRC, the gear ratios on an SM420 are as follows:
1) 7.06:1
2) 3.58:1
3) 1.71:1
4) 1:1
R) 6.78:1
That, coupled with a 4.55:1 in the rear would be about right for 50-55 mph, depending upon wheel and tire size.
Here\'s the tool I used . I used the 235/75R15's that I have on my '46 as a reference; I don't know what size tires your truck is sporting.
If you can find a diff carrier from a 67-72 3/4 or 1 ton pickup truck (you don't need the whole pumpkin), you can swap it out for the one you've got now. You'll need to find an automatic, and then you'll only probably score a 4:10 diff (About 55-60 MPH). If you're REALLY lucky, you might be able to get a 3.90:1 carrier, but these are VERY hard to find. If you did manage to score one, you'd get 60-65MPH.
Just remember that you need to be able to stop. Huck brakes work fine (as do bendix) so long as they're adjusted correctly, but the faster you go, the longer it takes you to stop. Even at 50 MPH, the force that your brakes exert doesn't 100% counteract the momentum that your truck (mass times velocity) has.
#60257 05/10/2006 2:24 AM
thanks..thats just the ticket.
thanks
#60258 05/10/2006 6:04 AM
No problem. grin
