1 members (Danielbolt), 163 guests, and 4 robots.
Topics128,149
Posts1,056,818
Members48,454
#6024 03/29/2005 4:42 PM
old truck heaven
old truck heaven
Hi: I am interested in finding out if a 292 CI chevy engine from 1962-65 chevy truck will fit into my 1942 Chevy 3/4 ton. Is the block the same length as the 216 I have in there now?
Brian
No, the 292 is about the same height as the 235/261 but will be a few inches longer. The 292 will also be about 19% lighter. You will have to move the radiator forward or cut the firewall and set the engine back. You should also know the motormounts, crossmembers, transmission, and driveline will all have to be changed. Joe
Repguy, I put a 292 into a 54 6100 recently. The transmission bolted right up to the bell housing. I did not have to change the clutch or the cross member. I cut the side motor mount perches out of the truck that I got the engine from and cut them down to fit the narrower frame of the 54. Because the PO had cut out the radiator frame allI had to do was bolt the radiator onto the front side of the frame.
Umm...according to some original GM information in Santucci's book, the L22 I6 is actually 2"-3" shorter in length than the earlier Stovebolt engine. The 292 is about the same height as a Stovebolt engine, while the 194/230/250 is a few inches shorter in height.
1954 GMC De Luxe COE
The 292s were built for many more years as industrial (irrigation) engines. I suspect you could still buy a brand new one from GM.
old truck heaven
old truck heaven
Thanks to all responders.
I would like to find a good 292 with a 4 speed transmission. Good running working condition oir a rebuilder....anyone have a lead on one?
Thanks again.
Try the swap meet area below on the main forums page.
I've got a good 292 in the swap meet section.
