Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Dakota Bob, TUTS 59, Otto Skorzeny), 109 guests, and 2 robots.
Topics128,282
Posts1,058,492
Members48,490
Junior Member
Junior Member
My new 45 1.5 ton has a 3 speed gear box about 3' behind the transmission. I think it says spicer on it looks like it was added later. I belive it started life as an army truck. Havent had time yet to figure out the ratios yet but i will, are these common ? Any chance it's an under , over, and a straight through?
3B Offline
Hy boom
construct, what you have is an auxilliary transmission, could be a two or three speed. They were common in bigger trucks, see if you can locate an I.D. plate and give us the numbers, hope that helps.
I installed one in a 46 1.5 ton and it works like a Hank. The one I'm useing is a three speed under straight through and over. Top speed in under is about 30 mph I have' nt had the nerve to go to the max in over probly some where around 80 or 90. I think this would be a good fix for most people wanting overdrive instead of useing the light weight I want'a break alum. car trannys.
Junior Member
Junior Member
Its definetly a 3 speed and I'll try and get some more info off the data plate .Theres a #3 stamped on it the rest is a little tough to read But I'll carfully clean it up and see if I can come up with a number. Thanks for the info.
