6 members (Gdads51, MickeyP, tclederman, Bill Hanlon, Joe H, HandyAndy), 81 guests, and 1 robot.
Topics128,049
Posts1,055,695
#601226 12/14/2009 8:31 PM
Here is my situation guys. The hoses from my heater, coming from the firewall, have been disconnected from the water pump and I am in the process of putting the whole setup back in place. I was looking under the dash and I found a single wired switch with "Air" stamped on it? There is one wire on it that seems run to the rear of the heater motor, not sure yet, need to dig in deeper to make sure. The switch has a ceramic resistor on it and it has a place for what seems to be a fuse. The side where the "fuse" goes,has a small screw with an electrical eyelet attached,and I can see where a wire used to be attached to it, but no longer is and no sign of the loose wire in sight. Anyone have some info? Thanks!
Kato #601242 12/14/2009 9:32 PM
Ex Hall Monitor
Ex Hall Monitor
And your truck is?????
Kato #601245 12/14/2009 9:37 PM
One is power from your trucks harness often times ignition switch, the other provides power to the motor which is grounded by contact with it's attachment bolts.
Follow this link for illustration:
http://chevy.oldcarmanualproject.com/accessories/1951am/51aim35.htm
Brad, thanks for the info, it was what I was looking for!
I guess I forgot to mention, 55 1st series 235 with second series engine. As I was typing it out, I kept reminding myself to not forget year and series, but I forgot what I reminded myself of! Thanks Guys!
Kato #601360 12/15/2009 4:58 AM
Do you have a 1955 first series truck with a second series 235 ?
1951 3100 Chevrolet
bowtietim,
I have a 55 1st series truck, with a second series 235 engine. I've had some challenges trying to obtain some engine parts for it! I ordered a new cam from Egge, twice, and it was the wrong one. They crossed referenced the number on my old cam and sent me the one that "matched", and the front end of the new cam, where the gear is attached, wouldn't fit through the front jounal?? So I took my original to a shop to have it re-ground. Same with push rods for said engine. Book calls for length of 11+, but it takes the shorter ones, 10 5/8, that are for a 54 235? Keeping records of all that I am doing, don't want to duplicate my errors! Take care!
Kato #601412 12/15/2009 1:46 PM
Kato,
This thread has moved in the direction of your engine.
What are your block casting and block date codes, and engine serial number code?
tclederman,
I will move this over to the Engine forum under the heading, "Block Casting Dates", when I get the info. Thanks!
