| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60136 05/07/2006 6:06 AM | Joined: Dec 2003 Posts: 61 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 61 | I want to update the front axle in my 64 4x4, to an open knuckle & Disc brakes. I have a 1980 1/2 ton donor truck with all the parts I need, steering, MC, Etc. My question is, the 64 has 3:73 gears, and the 80 has 3:08 gears, is anything internally interchangeable between the two axles? or should I just look for a truck with the correct 3:73 axle that I need? Thanks! | | |
#60137 05/07/2006 12:03 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If you have a matched pair from the donor change them both, with the brake booster and propotioning valve from the donor the brakes should work fine. Also the 308 gears should help the MPG. | | |
#60138 05/07/2006 1:14 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Sorry if this is not relevent, but if you are changing just the front axle on a 4wd. won't this be a serious mismatch of ratios? | | |
#60139 05/07/2006 9:13 PM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | In theory you could match up your ratios by changing tire sizes,but that's a real bag-o-snakes to get into. You can swap a set of 3.73 gears into the newer axle,but it won't be cheap. Best option would probably be to use a wrecking yard hotline and try to find the kind of axle you want with a ratio that matches your other axle.Or if you want to go for the 3.08 ratio,go for a donor truck and use both axles. If you go this route,don't forget to grab the speedometer gear too,if it's available. Speed | | |
#60140 05/08/2006 4:34 AM | Joined: Dec 2003 Posts: 61 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 61 | Thanks everyone! Sounds like I'll look for a 3:73 donor. This ratio works good with the 292, and I would like to pull my trailer a few times a year with it. ttodd, you are right about the gas mileage, I have 3:08 in my 71. | | |
