Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#600519 12/12/2009 1:04 PM
I have the opportunity to buy this engine locally from a guy at work that just picked up a truck. It's a 235 that doesn't turn over. My 235 is fine and I would be buying this one mostly for the damper and road draft tube. My damper isn't stock so my fan is spaced out 1" and I have broken a fan pully before. I have a NOS pully on now and 2 spares. My draft tube just doesn't have the bracket to bolt it to the engine.
Do stock dampers contain rubber that could be deteriorated?
My other idea was to paint the tin and manifolds of this engine and put them on mine as done, but these would all need blasting.
I could probably get it for $40 or less, but I don't really want the block taking up space either, so it would have to go soon.
Thoughts?
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
Yes Dampers have rubber that can be deterioraed and there are shops that rebuild them I'm sure somone here can give You a name .
For 40.00 bucks You can get alot of parts off it carb, vent tube, damper, ETC.......
Put the block and head on Bolt somone is always looking for "PARTS" Give away free for the cost of shipping
Pete
Eric,
Likely the parts you are interested in can be bought individually from Stovebolters here or on sights like EBay and some aftermarketers that sell used or NOS parts. Unless, you just want to play around with pulling apart the 235, I personally would pass on it. And yes,the damper deteriorates although there are rebuilders for them if you want to do that.
Drew
Well I'd advise that you at least look it over first and see what all is included. Generator, starter, carb, manifolds, an 848 head? Maybe it's really a 261?
I just looked at the pictures and if that is it then RUN don't walk to see the guy and pay him quick. There are guys who would eagerly give you the 40 bucks back just for the oil filter. Lots of other goodies too.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
0
0 Offline
In the AMC hobby we call that reluctance to spend: "Rambler mentality". The days of the $5 road draft tube and the $10 aor cleaner, not to mention the $10 harmonic balancer are long gone. If you can use parts off of that engine and you have a place to store it, buy it.
heck, the cast iron alone is worth at least $15 for scrap.
For forty dollars,i wouldn't even think twice about it.That's a complete engine,buy it.
1951 3100 Chevrolet
I paid $200 for an engine like that. I had it rebuilt and am driving it in my 55. Runs great and I am happy.
Dennis
