| | | Forums66 Topics128,088 Posts1,056,109 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#6001 10/22/2004 10:17 PM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Hi, I have a 1950 Chevy 1/2 pick-up and I am trying to decide on mounting the master cylinder to the firewall or under the floor. What are the advantages and disadvantages to changing to a firewall mounted? Thanks for your help.
Everything you know is wrong.
#6002 10/23/2004 12:04 AM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | low: first off where do you need the room, under the cab if you are putting in a V-8 if you are staying with the 6 then firewall. I decided I did not want to fill my resevior thru the floor so I closed that off and put the master cylinder under floor but put resevior on fire wall. So that is another option.
popcorn The Truth is Out There (Good luck) | | |
#6003 10/23/2004 12:19 AM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | I am going to be going with a small block V8. How about drive-ability? Is there any major difference in applying the brakes? I have always driven vehicles with firewall mounted brakes. Is it going to "feel" weird pushing the brakes down if I mount underneath? Just wondering. Thanks for your help.
#6004 10/23/2004 11:25 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Anybody else ever seen the firewall flex?.....not what you really want the brakes master to do!! Honest!! | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | low: lets put it this way I grew up with the old way and just passed on thru to the new way. Most of us have put the new brakes on and I haven't heard of any complaining. of course mine looks real purty bolted to the frame because thats about all thats on it. (LOL)
popcorn The Truth is Out There ( Good thought on the flex guys )Ben | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | My thoughts on this are that when I get to doing the cab area of the body on my AD panel, I would cut the floor and firewall from the front of the seats forward out of a newer donor truck and weld it into the oldie, then fabricate the body mounts. This will give me the newer style pedals and a solid floor. I have seen the MC on the firewall with a SBC V8 so I know it can be done. Am I thinking wrong?
Also, seems I have seen kits for firewall mounted MC that includes reinforcements to stiffen the structure.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Profitt is right--if u are gonna put a mastercyl on ur firewall--you need stiffening to eliminate flex of the firewall. Here's a link on a swing firewall mounted pedal Classic Truck Brakes web page Best to reasearch brake stuff thoroughly before you start hackin on firewalls and floorboards. Stopping is important.
Buzz'n Half Dozen
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | New trucks???? NEW TRUCKS SUCK!!!!
In the 39 the firewall gas peddle flexes....don't tell me about brakes not.....New trucks are designed with folds and ribs...curves to support at structure
Old truck's firewall is flat.....lottsa flex!!!!
Tie the brake to the frame something that doesn't flex too much | | |
#6010 10/24/2004 11:59 PM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Is it going to "feel" weird pushing the brakes down if I mount underneath? sbigelowWith the master cylinder under the floor the kits are designed to work the same way the pedal on the truck works now (Assuming you have those pieces  ) The pedal will go forward and down, really close to the way it works now you'll just have a different cylinder under there to hook to. You won't be pushing down. I'm going with the under floor route on my 53 just cause I want that truck to appear pretty stock. On one of my other trucks I'm planning on using a S10 Mastercylinder mounted on the fire wall as that trucks gonna be more of a running around driver. With a newer I6 (250CI) engine and auto tranny. MONGO Also one of the local streetrod supply places has an access door I'm planning on using on my 53(under cab brakes) This will give me a nice large door in the foorboard with a gasket to make checking and filling the resevour easier. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | So where would someone get a kit to replace the original master cylinder with one that can be used with the fronts upgraded to discs?
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Thanks guys. I think I am going to go with under the floor approach. I did find some nice firewall mounting brackets from www.classicperform.com/ Thier brackets create a triangle between the firewall, dash and steering column. Should eliminate any possible flexing. I think I will go with the under floor master cylinder simply to keep the engine compartment clean.
