6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
#599779 12/09/2009 8:20 PM
Can someone tell me where the heater hoses coming from the firewall connect to the water pump? Does it matter which hose is where on the pump? (235 second series engine in a 55 first series truck) Thanks!
i don't think it matters, the heater core is just a small radiator that doesn't care which way the fluid flows.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I took My top hose from stat housing to the heat control from heat control to the core and than from the core to the lower heater conection on the water pump but I do not think it matters much it looked better on My truck the way the hoses laid.
Pete
The hose from the stat housing goes to your heat control connection closest to the firewall.Then from the other connection on the heat control it turns and goes through the firewall to a rad core connection. From there it goes from the other rad core connection back to the connection at the water pump Use grommets where the hoses go through the firewall.
It's fun to drive and to work on. How much better can it get
51 John has it right. If it's the other way hot water still gets to your core when the valve is shut.
