3 members (RLB, 1955 1 Series, Peggy M), 101 guests, and 1 robot.
Topics128,105
Posts1,056,542
Members48,448
#599481 12/08/2009 11:34 PM
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
10 over for a SBC
Is there such a thing for Small block Chevy [327 cu ] ???
I have a block that is a little sloppy and a 10 over would take care of it AND we could do it in shop .
Does anyone know where I may get these ?
Dan
It's VERY unlikely, plus it would be hard to find a machinist willing to spend the time setting up a boring bar to take an accurate .010" over cut. The last .003" or so have to be honed out after boring, so the shop would have to set up a boring bar to a dead-accurate cylinder centerline, make one pass of about .007", remove the boring bar, and hone-fit the pistons. If you could find pistons, (unlikely) and rings (even more unlikely), and then locate a shop with a Sunnen CK-10 power hone, you could get them to diamond-hone the cylinders to 10 over. .020" is about the most common first oversize. BTW, most cylinders wear somewhat egg-shaped, so you might not get a clean cut all the way around with less than a 20 over cut.
even if they make them, it might be cheaper to pay to have them bored to .030 over since those are pretty common.
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
Found the tens
Thanks for the advise all
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
Summit has stock, 0.020, 0.030, 0.040 and 0.060 over
