2 members (dt235sd, J Lucas),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,102 Posts1,056,532 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Oldog in Md. Unregistered | | Oldog in Md. Unregistered | 10 over for a SBC
Is there such a thing for Small block Chevy [327 cu ] ???
I have a block that is a little sloppy and a 10 over would take care of it AND we could do it in shop .
Does anyone know where I may get these ? Thanks Dan | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | It's VERY unlikely, plus it would be hard to find a machinist willing to spend the time setting up a boring bar to take an accurate .010" over cut. The last .003" or so have to be honed out after boring, so the shop would have to set up a boring bar to a dead-accurate cylinder centerline, make one pass of about .007", remove the boring bar, and hone-fit the pistons. If you could find pistons, (unlikely) and rings (even more unlikely), and then locate a shop with a Sunnen CK-10 power hone, you could get them to diamond-hone the cylinders to 10 over. .020" is about the most common first oversize. BTW, most cylinders wear somewhat egg-shaped, so you might not get a clean cut all the way around with less than a 20 over cut. Jerry
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | even if they make them, it might be cheaper to pay to have them bored to .030 over since those are pretty common. | | | | | | Oldog in Md. Unregistered | | Oldog in Md. Unregistered | Found the tens Thanks for the advise all | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 |
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Summit has stock, 0.020, 0.030, 0.040 and 0.060 over
