2 members (Southerntruck, Danielbolt), 109 guests, and 2 robots.
Topics128,154
Posts1,056,831
Members48,456
#599428 12/08/2009 9:05 PM
I've purchased a restored stock radio for my 59 chevy 1/2 ton. I also picked up an original speaker and cover from the local yard. I was able to clip the speaker wires in the yard so I have about 5 " remaining. The ends of the speaker wires are a round plug type. My question is does anyone make these connections? Is this wire still available? I purchased a complete wiring harness from YNZ but it did not include the radio wires or speaker wires.
The wires coming from the radio seem to be okay and have typical connections. I have the wiring diagram so I think I can get that connected.
Also I am looking for the radio support bracket under the dash for installing the radio. I have posted in parts wanted with no luck.
Thanks again
Brian M
if you have something like Radio Shack within reach they may have the connectors, but they can be removed from the old wire pieces and soldered on new wire - for the wire, anything about the same size will do .... for the support, not a complex piece, you can fab one up from these dimensions
also the radio service booklet is here if ya wanna copy it down
Moderated by  truckernix
