| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | I've purchased a restored stock radio for my 59 chevy 1/2 ton. I also picked up an original speaker and cover from the local yard. I was able to clip the speaker wires in the yard so I have about 5 " remaining. The ends of the speaker wires are a round plug type. My question is does anyone make these connections? Is this wire still available? I purchased a complete wiring harness from YNZ but it did not include the radio wires or speaker wires. The wires coming from the radio seem to be okay and have typical connections. I have the wiring diagram so I think I can get that connected. Also I am looking for the radio support bracket under the dash for installing the radio. I have posted in parts wanted with no luck. Thanks again Brian M | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you have something like Radio Shack within reach they may have the connectors, but they can be removed from the old wire pieces and soldered on new wire - for the wire, anything about the same size will do .... for the support, not a complex piece, you can fab one up from these dimensionsalso the radio service booklet is here if ya wanna copy it down Bill | | |
