7 members (55shaker, TexasA&M48Truck, MickeyP, Ponchogl, Hotrod Lincoln, Nick in Manitou, 1 invisible),
126
Mod | | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | OK all you stovebolt goorues, I hope I don't stump you on this one.... This was mounted to the firewall of a 1950 3100 chevy truck. It was not hooked up to anything, but It looks to me like some kind of pump for the wipers or the wash on the wipers. The motor had DELCO APPLIANCES NY USA stamped on it where the pump and the motor coupled together with a 6 pt type of shaft and the pump was marked TRICO and a list of patent #s and reg.#s hope you can see from the pics that the motor has 3 wires and the pump has 2 barbed hose ends for vacuume or wash soap? Almost sure the motor is 6v(not tried it yet)was this something dealer installed or what? I didn't know of wash nozzels on the front of the truck hood or cowl vent? Whatcha think? [img=http://img33.imageshack.us/img33/3083/pc060025.th.jpg][img=http://img32.imageshack.us/img32/4721/pc060027.th.jpg][img=http://img525.imageshack.us/img525/1628/pc060026y.th.jpg]Thanx for your help folks! Mike
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It is a vacuum pump. I have one on my 40 dodge, does it work? | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Havent tried the motor yet. Do I hook the hose from the wiper pump or do I unhook the dash pump and use this? Thanx | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The dash unit is the wiper motor and it is runs on vacuum. My old dog don't run yet but both are hooked up. manifold to pump, pump to wiper motor so the unit in question acts like pump vacuum booster. The motor on it looks like the heater motors so you can probably replace it with a 12V unit. | | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | That pump is easily replaceable with a 12v wiper motor, i tossed the one in my 54, but it looks like you have a deluxe model or something, mine was shaped like a semi-circle and didn't have any wires. I'd just plug the manifold port where it attatched with a threaded brass fitting from the hardware store. | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | This motor has a recessed hole to accept the 6 point shaft, my Heater motor has a extended shaft for the blower cage to go on. Can I just use a voltage 12/6 reducer if I plan to use it? Also I still need the motor/pump under the dash? This is better than a vacuume can by far! Thanx | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Unless I am mistaken, that is not the wiper motor you have there it is a vacuum booster to assist the vacuum operated wiper motor under the dash. You will need both unless you want to toss them at me and buy the high dollar 12v wiper motor from one of the vendors. I would guess that Chevrolet 3100 threw away his wiper motor so he may be needing one or bought the aftermarket electric unit. | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | FriedGreenTmater, That sounds mity inviting, but I kinda like a little of the 'ol school stuff left on my truck, if I can get it to working.lol If so it probrobally will work better and longer than todays stuff. Thanx | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey Brad, Do you by chance have the wiring diagrahm of the three wires on my motor? Thanx | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I will check the books tonight. | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | | | |
