| | | Forums66 Topics128,271 Posts1,058,416 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 39 Apprentice | | Apprentice Joined: Oct 2009 Posts: 39 | wondering if there is any way to repair a steering wheel that has small cracks and can it be prepped to paint? If so how? Thanks again for everything!  | | | | | Joined: May 2005 Posts: 335 'Bolter | | 'Bolter Joined: May 2005 Posts: 335 | Eastwood has a steering wheel repair kit with epoxy for filling cracks. Then primer and paint. That is what I'm going to use to repair my steering wheel. Samantha | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Here's a thread from awhile back that has some info and options. Have fun and good luck Dan | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Go to any FLAPS or hardware and get two part epoxy just get the better stuff and V the crack out a little fill with epoxy than sand and paint I just got done doing that to My 52-3100 wheel and it looks good .
Pete | | | | | Joined: Feb 2000 Posts: 5,266 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,266 | I used JB Weld, V out the crack, fill with epoxy and use tape over it so it doesn't run out. Sand it smooth, prime, resand, prime, and paint. I used Epoxy paint from the local ACE hardware.
Joe | | | | | Joined: Oct 2009 Posts: 39 Apprentice | | Apprentice Joined: Oct 2009 Posts: 39 | Thank You,everyone!All of your ideas and experience is really a help,a big help.I'll take some pics and be assured I couldn't go at it alone,thanks again for sharing  | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | i tried the steering wheel epoxy from classic part of america, but didnt like it. i V'd out every crack, which my wheel had many, then used j-b weld, applying it in about 3 different layers, sanding in between, then finished with some bondo spotting putty. fine sand, then just good old rattle can spray paint, primer, black, then clear. you can step through my album for pics. http://s251.photobucket.com/albums/...00/?action=view¤t=DSC01710.jpgleonard | | | | | Joined: Oct 2009 Posts: 39 Apprentice | | Apprentice Joined: Oct 2009 Posts: 39 | Very informative RRKing.I opted for a two part epoxy PC-11.I thought my wheel looked bad,the cracks on mine were miniscule compared to yours.I hope mine ends up as good as yours.Its all in the prep work right?So I take it you didn't use Krylon Fusion for plastic, rattle can paint?That's what I'm using after priming of course. Thanks for the pics.Nice truck  | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | no problem joseph... yes, my wheel was cracked pretty bad, and i didnt use any special stuff for plastic, before paint, just the good old rattle can stuff. LOL.
take care and good luck.
leonard
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I see I had some inputs on the thread that Dan Chev4T6 pointed you to. As a follow-up, here we are nearly 2 yrs later and my paint job STILL looks great. Just make darn sure your filler sanding job is good. By "good" I mean, "like how you'd do it if it were a fender or a door." I didn't do a good enough job and (naturally) the paint shows my lack of attention.
But the epoxy filler and the paint worked out wonderfully. Be sensitive to "operator error"!
BIll | | | | | Joined: Mar 2009 Posts: 13 Apprentice | | Apprentice Joined: Mar 2009 Posts: 13 | I have the same problem,i found an original 53 3100 steering wheel in a swap meet, (my has a 70s steering wheel on it) what kind of paint should i use, so it doesn't crack? Also, how do i remove the horn from the wheel without tearing it up, when i am ready to install it on my truck? thanks for the info,
"FLY ARMY" 1953Av8tor 1953 Chevy 3100 "Airspeed, altitude and brains - two are always needed to complete the flight successfully"
| | | | | Joined: Mar 2009 Posts: 13 Apprentice | | Apprentice Joined: Mar 2009 Posts: 13 | Also, how do you V the crack?
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | You can use a triangle file be sure you get a small coarse one. Then sand down any file marks on the edges of the wheel. You could use a Dremel tool with a cut off blade or a fine saw blade. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | Also, how do you V the crack? i used a dremel tool. leonard | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | I just went out and bought some JB Weld in the putty form. I already had the regular two part but working the as yet un-hardened putty with water has GOT to be easier than sanding it or grinding it off after its hardened. Pictures upcoming. | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | what kind of paint do you guys use and do you use a clear coat or some kind of sealer
1938 Gmc 1/2 ton
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I used basic plastic paint - spray can stuff. Put about 6 coats on it and after more than a year, it's in excellent shape.
