8 members (Hanks custodian, baldeagle, TexasJim50, crenwelge, ndkid275, Gone, RaNfLaS, 1 invisible),
23
Mod | | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59818 04/28/2006 4:49 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | While driving my 12 years in restoring 53 chevy pick up over a rough place in the road I heard a strang noise, and was wondering if the rods could have hit the dipper troughs.It has happened a few times since I put it on the road, but is not a regular noise, Thought it was the fan hitting something but showes no evidence that it's the fan blade. Any ideas????? | | |
#59819 04/28/2006 7:13 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Without hearing the noise it's difficult to diagnose. One thing for certain is that if it's the dippers hitting the troughs you have something awfully loose. If you think that's what it is you really need to pull the pan. If a dipper hit anything it's now bent. If it's bent it's not oiling. If it's not oiling you are in trouble. Personally I don't think it could be a dipper if you're still driving the truck but without hearing it anything would just be a guess.
#59820 04/28/2006 8:45 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Maybe the flywheel is touching the cover occasionally.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#59821 04/29/2006 4:22 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I had a customer that had a starter return spring that was to weak, so the starter teeth would just touch on bumps, and do just what you are describing.
See the USA in your vintage Chevrolet! My Blog | | |
#59822 05/18/2006 10:35 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Found the problem.The overflow tube from the radiatior neck broak the clamp on the side of the radiator and would allow the tube to flop up and hit the fan blades, noticed paint gone from the ends of the fan, since I restored the truck my self I know every square milimeter or for us SAE guyes square inch, man what a bullet I dodged | | |
