| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 20 New Guy | | New Guy Joined: Jan 2009 Posts: 20 | I am getting ready to do my wood bed on a 55 first series , I have to replace the side strips along with the center strips. How is the best way to install them and get them in the original position? I drilled out the spot welds and I am not a good spot weld so I guess I will use 5/16 bolts instead of spot welds. thanks for your advise,
" Hard Times Don't Last , Strong People Do."
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Many people use the bolt system,especially stainless steel.
Drew
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | The side strips as you know are spot welded on. I am not sure how you could bolt them on and not have a bolt head or nut showing on the out side. Most of them would be under the fenders, but the end one would show. Maybe some one makes a special bolt set for this. Check with the vender's in the Links section.
Joe | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | We have compolete instructions on the website http://www.mar-k.com/installation_hints.html for installing your angles, whether welding or bolting them. Go to the link and scroll down to the instruction for Angle Strip removing and installing for 54-72 GM trucks. For exposed bolts, use Acorn nuts to protect the threads and for cleaner appearance. Mar-Ktech | | |
