| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | hi,
i'm in the process of rebuilding the brake system on my '54 3/4 ton.
on the top of the backing plate, near the wheel cylender, there is a pin that the top of each pad rests against. it is held in place by a large nut (5/8 or so). the pin is on an ecentric and can be adjusted and set by the nut. what is this adjustment for?
thank you. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | That's the anchor pin and it can be adjusted to center the shoes in the drum. Here's the procedure. | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | | | |
