0 members (),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Spanky, there may have well been 2 different 707 engines. The 707 of the 30's didn't resemble at all the other engines in the series you mention. That whole series of engines is pretty obscure because they were in heavy trucks that were run into the ground and scrapped. Smaller trucks were used by farmers and a lot of them spent most of in barns. I just don't have much information on the earlier big trucks and I don't know of anyone who does. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | It's not GM, but my '68 Seagrave Fire truck has the Waukesha 817 Straight-six in it, and it sounds like a MONSTER. Of course, compared to Diesels, it's not so loud, but yeah, you hear it coming. These engines I think were born in the early 50s, as the 145GZB, same engine, different name. Two plugs per cylinder, dual ignition, dual batteries, oil cooler, governor . . . a beast.
Been around the Mack 707 a lot, too. Buddy had one with a knock, turned out to be a hole burned in a piston - wrong heat-range plugs, and plug was loose in the whole, let air in. Lean condition led to overheating. He ended up buying a whole other truck to part out, just to get the replacement piston he needed.
Rebuilding a 235 is a LOT cheaper! ;-)
-Michael | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Wow, Freq that was cool. Now think of this if you did the same with a two ton LCF and grafted a standard two ton truck front end on you could have a V12 powered two ton that looked relatively normal. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Or maybe it would be easier to start with a standard two ton truck cab and put the LCFs' floor board in it then lift the cab on the frame and use the LCFs' running boards. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | ..."That sounds too cool, even if it was just on a display stand it would be an interesting piece of machinery to tinker on." Still doesn't carry the monster quality of the GMC V-12, (something else I'd love to have), but that's still a huge engine!"
Bill, thats the same reason I want a harley...not the whole motorcycle mind you, just the engine on a stand. Something I could put in the garage, go out there once in a while, start it up and listen to the "potatopotatepotatoe" for a few seconds, then shut it off and go back in the house. Or maybe a JohnDeere A would do...hmmm.
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Or maybe a John Deere A would do...hmmm. I have a 1951 John Deere Model A for you!
Bruce | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Dave,
I got something different for you. I've got a John Deere with a 2-53 Detroit Diesel.
I also like Harleys. I had a '72 Sportster with long chrome straight pipes. I like how you described it. It sounds just like that ...till you rev it.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | the biggest 6 i ever worked on was a diesel locomotive it had a alco 539 a massive 12x13.5 bore and stroke so thats what 1530ci per hole and a screaming speed of 900 rpm and 1000 hp | | |
