4 members (Gdads51, bobwithm, TUTS 59, 1 invisible), 133 guests, and 7 robots.
Topics128,088
Posts1,056,124
Members48,435
#597600 12/02/2009 8:24 PM
So when they say SAE 90 Hypoid for the transmission and rear differential...can I use SAE 75W90 API GL-5 in both? I just read that some older vehicles cannot handle the EP additive due to the copper on the gears? Has anyone heard of this?
Riding in the Passing Lane
It will work fine in both.
1972 Chevy c10 Cheyenne Super
There is no copper on the gears .
In the gearbox, there are bronze bushings in the reverse idler layshaft .
In the diff, there are bronze alloy thrust washers behind the axle gears.
If one oil is good for the diff , it will be ok , in that aspect , for the g/box.
There are some oils that eat the bronze alloy bushings , I had this in my 4spd once , fortunately I checked it just a month later and saw the oil was heavily metallised , sparkly golden!!.
No permanent damage was done .
The extreme-pressure additives in rear end grease can have a detrimental effect in some transmissions, but I don't think anything smaller than a Fuller Roadranger will show much of an effect. The shearing effect of the spiral teeth on the ring and pinion gears in the rear end creates friction that the film strength of plain oil cannot handle. The Roadrangers I used to maintain needed to use "straight mineral oil" as we called it, without the hypoid additives. Hypoid lube had a tendency to fill the grooves in the brass synchronizer rings with carbon, for some reason. If I tore down a Roadranger, and the synchro rings were black, I knew it had been running EP 90, not mineral oil.
In my 1940 1/1/2 ton and my '42 Diamond T I use WARREN GL-1 gear oil. The transmission in my Diamond T has bronze thrust washers. I also use it inmy differentials. If i used a GL4 or 5 the EP additives would "eat" the bronze.
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
J Gott #598158 12/04/2009 2:30 PM
Sounds like there are contradicting opinions. I meant bronze but typed copper for some reason.
So does a 3 speed 1946 transmission and rear diff have bronze in the gears? Will the GL-5 additive eat the gears? What is my alternative?
