0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | no ,not by the the wife ,, just the clutch on the 59, 4-on the floor,283. and the peddle feels really easy to push, sometimes hard to put in gear,when in gear and i giver her too much she'll chatter, as soon as i let off and apply gentle accelleration she's fine and it doesn't slip in any gears? this is not my daily driver just the one i'm starting to work on. which has been sitting for a while. :confused: | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I would guess it's all rusty. Possibly the disc has been glazed from slipping.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | no real cure then besides replacement? | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Sounds to me like things are just wearing out and probably time for a clutch kit. My '65 started shuddering a few months after buying it and gradually became worse along with noise from release bearing. At first I could kind of find that sweet spot to accelerate more smoothly but, after a bit, it was all shudder. Threw a clutch kit in and she was all good up 'til I installed the T5. Your disc could be glazed. Your flywheel could need resurfacing. Oil could be getting in there. You pretty much have got to take things apart to see what's goin' on so, you may as well just install a new kit while you've got things apart. Or, drive it 'til you can't stand it anymore or 'til it breaks but, speaking from experience, it pretty well sucks when you're out and about and the clutch decides to take a crap. -David Kustoms-and-Sleds | | |
#5977 04/09/2005 11:34 AM | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | thanks , again oh wise wrench gods, i shall say a prayer and spray some w-d in the wind... | | |
