10 members (55shaker, Jeff Ogden, Gray_Ghost, RoadsScholar, Ponchogl, fonz8261, Guitplayer, Cletus1950, Otto Skorzeny, carbking), 92 guests, and 1 robot.
Topics128,131
Posts1,056,721
Members48,454
Is there any difference between the 48 and 49 front end on the 1/2 ton Advance Design chevy pickup?
The 1/2, 3/4, and 1 ton hood, fenders, and grilles are the same from '48 to '53.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
So axel and and everything to do with the steering are all the same?
I thought you were talking about sheet metal. I'm not sure about the front axle. Someone else will need to answer that one.
David Colter
'48 and '49 are the same, they both have Huck brakes and lever action shocks, assuming no one has swapped them out.
Axle, spindles, hubs, drums, steering linkage all the same
Ray
