0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 7 New Guy | | New Guy Joined: Dec 2006 Posts: 7 | I have a '53 AD 3100 with a cab that needs complete replacment of floor Pan and seat riser, toe board, kick panels, corners,cowls... too much. I have been looking locally for 47-53 restorable cab but have turned up a '54 good cab(no doors). My question is what additional sheet metal would I have to find (aside from a grill) to go to the '54 cab?
Jas
| | | | | Joined: May 2005 Posts: 39 'Bolter | | 'Bolter Joined: May 2005 Posts: 39 | If you have doors on your '53 they will work on a '54 cab. The door strikers may be different, but the doors will work. You will also need a pair of front fenders, as there is some difference between the fenders for 47-53 trucks and the fenders of a 54-55 truck. Some guys have installed a complete 47-53 front clip on the cab of a 54-55, so that may be an option for you.
Others, with more experience and knowledge, are sure to offer you their advice. Good Luck
