| | | Forums66 Topics128,277 Posts1,058,456 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59533 04/23/2006 4:45 AM | Joined: Mar 2006 Posts: 16 Junior Member | | Junior Member Joined: Mar 2006 Posts: 16 | my 45 1.5 ton showed up today in very good shape it looks so cool out there in the yard Ill be posting alot of questions in the next few months as restoration begins. First I,d like some help determining what engine I have it looks newer than orginal. What am I looking for? | | |
#59534 04/23/2006 5:50 AM | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy boom construct, could you take some pictures of the engine, and take down any casting numbers on the head or the block, if you give us enough clues we'll figure it out, hope that helps. | | |
#59535 04/23/2006 2:13 PM | Joined: Mar 2006 Posts: 16 Junior Member | | Junior Member Joined: Mar 2006 Posts: 16 | Yes I can do that, where are those casting #s located? thanks. | | |
#59536 04/23/2006 2:22 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | On the passenger side in front of the starter. There are also stamped numbers in front of the distributor on a pad. | | |
#59537 04/24/2006 4:07 AM | Joined: Jul 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 60 | I would guess its a low pressure 235. My 2 cents. Jess
1951 3100
#59538 04/25/2006 6:31 PM | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | I'll guess 216 in a 1 1/2 ton. If it's later it could be almost anything. The pictures will help. The casting number sometimes is behind or under the fuel pump. The serial number stamped on the dist. pad is useful as is the casting date above or sometimes behind the starter. Good luck. Oh, Welcome to the Stovebolt Page!! :p
Professional Novice
#59539 04/25/2006 6:49 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | if it looks newer than org,,,if it,s a 4 bolt valve cover 235 full preasure,,if it has captin,s bars above the starter 261..if you are restoring and planning lots of driving go with a late 235 or 261 don,t spend a lot of money on the slinger if that is what it is...doc | | |
