| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | ok fellas' I am trying to put a 292 cu. in. in my 60' will it bolt in there without modifying it??? and the 6 cylinder motor I do have does not have any bolt holes in the front of the engine for the perch, is there specific years for this type of engine or am I just missing peices to make this work????? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 292 was never offered in a '60 but was offered in '63. I don't know from experience, but you may be able to adapt '63 mounts for a 292 to your earlier frame.
In '60 the standard six offering was a 235 that used a front mount. The later design motor (250/292) is usually side mounted like a V-8. The 292 uses side mounts that do NOT line up across from each other.
The 292 also does NOT use the same bellhousing as the earlier six, though if you 292 came from a 60's truck it will probably work in your '60, though you could have the hydraulic clutch version which will cause complications.
You might move these questions into the 60-66 area where hopefully guys with more details will speak up.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | to put that 292 in a 62 is that you are going to either put in the 292 mounting which inc the frame perches from a 63 and up. you have to use 292 pass side specifically as it is particular only to the 292. you could fabricate an eng mount for the front as per the existing 235 as log as you retain the bellhousing mounting the 235 bellhousing will not bolt up to a 292 as stated but any 283 bellhousing from that era 60-62 with a pass side hydr clutch setup will make life easier for the installation; they are fairly scarce. therefore you will have to fabricate a clutch setup for the drivers side and any 292 230 250 283 327 348 bellhousing (cast iron) wjth the side mounting will work. the other alturnative is to use the 63 and up 292 mounting and install an a/t behind it and use a rear trans mount and crossmember. you would have to remove the crossmember whichh goes under the bellhousing. your best option though would be to find that 283 b/housing with the pass side clutch lever opening. you sould look at the heavier models (60-62 c20-c50) which would have also used a hydr. clutch. some of those larger models may have used a 348 or 409 eng, those bellhousings will also work ron
| | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | I have three types of bell housings one has the passenger side clutch mount that I will use I just need to find the side mount frame towers to bolt the rubber mounts/engine to the frame..... | | |
