4 members (baldeagle, Joe H, 78buckshot, Shade Baby), 70 guests, and 6 robots.
Topics128,014
Posts1,055,329
Members48,419
#595198 11/24/2009 3:43 PM
Apprentice
Apprentice
ok fellas' I am trying to put a 292 cu. in. in my 60' will it bolt in there without modifying it??? and the 6 cylinder motor I do have does not have any bolt holes in the front of the engine for the perch, is there specific years for this type of engine or am I just missing peices to make this work?????
sdsmooth #595216 11/24/2009 4:35 PM
The 292 was never offered in a '60 but was offered in '63. I don't know from experience, but you may be able to adapt '63 mounts for a 292 to your earlier frame.
In '60 the standard six offering was a 235 that used a front mount. The later design motor (250/292) is usually side mounted like a V-8. The 292 uses side mounts that do NOT line up across from each other.
The 292 also does NOT use the same bellhousing as the earlier six, though if you 292 came from a 60's truck it will probably work in your '60, though you could have the hydraulic clutch version which will cause complications.
You might move these questions into the 60-66 area where hopefully guys with more details will speak up.
OldSub #595247 11/24/2009 6:44 PM
to put that 292 in a 62 is that you are going to either put in the 292 mounting which inc the frame perches from a 63 and up. you have to use 292 pass side specifically as it is particular only to the 292.
you could fabricate an eng mount for the front as per the existing 235 as log as you retain the bellhousing mounting
the 235 bellhousing will not bolt up to a 292 as stated but any 283 bellhousing from that era 60-62 with a pass side hydr clutch setup will make life easier for the installation; they are fairly scarce. therefore you will have to fabricate a clutch setup for the drivers side and any 292 230 250 283 327 348 bellhousing (cast iron) wjth the side mounting will work.
the other alturnative is to use the 63 and up 292 mounting and install an a/t behind it and use a rear trans mount and crossmember. you would have to remove the crossmember whichh goes under the bellhousing.
your best option though would be to find that 283 b/housing with the pass side clutch lever opening. you sould look at the heavier models (60-62 c20-c50) which would have also used a hydr. clutch. some of those larger models may have used a 348 or 409 eng, those bellhousings will also work
ron
padresag #599005 12/07/2009 4:32 PM
Apprentice
Apprentice
I have three types of bell housings one has the passenger side clutch mount that I will use I just need to find the side mount frame towers to bolt the rubber mounts/engine to the frame.....
