2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | My 59 SM420 was originally hooked to a NAPCO 4wd unit on a 3/4 ton. I am using it with my 59 1/2 ton with stock 235. It has a stock 1958 4:11 rear axle.
The 59 SM420 has been totally rebuilt and is really sweet for country rides and even the once and a while 50-55 mph highway ride but I have tried 3 different speedo drive gears in the side of the gearbox; a 11,12 and 13 tooth and none give me right speeds and NONE go over 35mph.
I noticed the teeth are different shape on the 11 and 12 than the 13. The finer teeth on the 13 are closer to correct than the squared teeth on the others. Were the speedo drive gears different for different years? How many ratios could they have had? The speedo is new and working fine......Tried 2 different cables also and they do not change the accuracy.... Is there a drive with more than 13 teeth? Thanks | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | If you're trying to make the speedo read higher you need a smaller speedo driven gear. The fewer teeth it has, the faster it spins around. | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Seems like the fewer teeth drives have too much of a squared off larger tooth surface. The drive inside the gearbox feels like it is more of a fine worm type drive. Perhaps the drive gears are specific to batch years of specific SM420's or trucks. I could not even get the 11 tooth to register a movement in the speedo and when i pulled it back out it appears the teeth are getting chewed on a bit due to a non mesh.. Just seems like it is not a clean drive fit. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Unlike the plastic gears in the later GM transmissions, where you could get away with just changing the driven gear, the drive and driven gears in an SM420 have to be changed as a set. There would have been a set for a 4:10 one for the 4:57, and a set for the 5:14. If you change only the driven gear you will chew up the drive gear and good luck finding another. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Hmmmmm, it almost sounds like you may have a gear for a different tranny. Check these guys out. Call the tel. no. on the web site and talk to one of the guys there, they know their stuff. Good folks to do business with too. | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Thanks guys......Denny that makes sense and I always thought that if you figured out which of the 3 ratios the gearbox had, you could match it by fitting the correct speedo drive. I thought they are 11,12 and 13 tooth to match the ratios.......but now I am wondering if that is too simple. Looks like the speedometer drive gears are perhaps a bit different depending on what vintage gearbox they came out of. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Those are not the only axle ratios involved either. This transmission was used '48 to '67 in 1/2-ton to 2-ton and possibly larger trucks. The probable rear axle ratio list would be pretty long...
3.90 4.11 4.57 5.14 5.43 6.17 7.20
And I'm sure this is not an exhaustive list.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If your speedo works and the drive gear and driven gear work in the trans, the easiest way is to correct it is with an adapter. Speedo shops can make them. Find your per cent of error either by using a gps or using the odometer and comparing it to mile markers on the interstate. The 54 GMC parts book lists 75 different adapters. These guys have speedo adapters. http://www.scottspeedometer.com/ | | | | | Joined: Feb 2000 Posts: 5,239 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,239 | Have you checked the parts manual, http://chevy.oldcarmanualproject.com/1929_57chevyparts/index.htmgroup 4.337 There is some information if you look a few pages back. Mostly part numbers, but it does list the driven gear tooth count for each ring and pinion gears set. Joe | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Thanks guys. Joe, I could not determine what group 4.337 was telling me when I looked. I do not think those tooth count published numbers relate to the driven gear that the cable goes into unless I am missing something.......
I would like to be able to find a reference for the tooth count on the driven gear(cable affixes to) to the various ratios. But the real issue for me since my SM420 is from a 59 NAPCO 3/4 ton frame, is how to determine what the INSIDE of the gearbox has in it for the other half of the driven/drive combo....
An adapter would be fine, but as Denny mentioned, the driven gear should match in a mechanical mesh so as not to be tearing either part up in the crashbox. I never thought to check that drive gear before installing the gearbox back in the truck. Live and learn....I will get it figured out even if it is trial and error. | | | | | Joined: Feb 2000 Posts: 5,239 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,239 | The parts manual really wasn't much help, but thats where I always go first.
Can you see the driven gear? maybe mark one tooth with white paint and count as you rotate? The newer transmissions use a round adapter for cable gear, you can rotate it around so a range of gears will fit one adapter. If yours is a fixed piece, then you and Denny are correct, and only one gear fits each driven gear.
Good luck in your hunt.
Joe | | |
