Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (UtahYork, Woodcmiami, frogfarmer, Otto Skorzeny, cmayna, 2 invisible), 123 guests, and 4 robots.
Topics128,281
Posts1,058,482
Members48,490
#594777 11/23/2009 3:23 AM
I am looking at a '61 C-10. It currently has a underbed gas tank that needs to be replaced. All the parts places I search show underbed tanks only available for '63 - '66. I assume the frame size is different. The current owner does not where the current tank came from. Can anyone tell me if one is available and where? Thanks.
Z
Z Offline
As far as i know, all 61's has the gas tank behind the seat. Your truck must be fitted with an after market tank or tank from some other model. Maybe your local chev club could help you identify it?
i think the underbed tanks were on suburbans originally. it must be a aftermarket or off something else like ziggynz44 said. i like the underbed tanks, have one on both my 63 and 64.
How about a '49-52 passenger car tank? Check out thread 8 of my build thread:
http://67-72chevytrucks.com/vboard/showthread.php?t=363509
No Limit Engineering has a sweet underbed tank for 60-62 Chevy Trucks as well. A bit pricey but nice. I'm picking one up for mine after Christmas...
No Limit engineering Gas tanks
1961 Chevy C10 Stepside
On my web site
chevy duty has a under bed tank
http://www.classicparts.com/WebCat3_spread.swf
SCOTTS SUPER TRUCKS
I got mine fron LMC for my 65 GMC $199. fit right and the mounting/locater tab's fit the existing hole in the frame, just had to drill holes for the straps. The filler neck is in the left read corner and will come out the back part of the fender, I will have to get some kind of a door for it right after I get a step side bed. I think the earlier trucks had a litle different configuration, might take some trimming.
You Learn more Listening than Talking
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
'72 chevy nova tank mounted under frame behind the rear wheel works great. Paid $20 for mine.
also try "early classic enterprises"
they make under bed tanks for the 60's trucks
