7 members (GMCJammer51, DaveV, Phak1, 1955 1 Series, Guitplayer, Gdads51, Napco Man), 77 guests, and 1 robot.
Topics128,132
Posts1,056,732
Members48,454
any body ever get rust spots like this and how do you fix it
[IMG]http://i590.photobucket.com/albums/ss350/jjfastback/PICTURES318.jpg[/IMG]
If that's the roof overhang at the windshield,I believe fellow bolter Alan's57 had similar problems.
I realise there is the age difference but rot is rot,whether it's a '57 or a '64!
If I remember correctly, he had to cut out the rust and replace it with donor panels cut from a junk truck.
Here's a link to his Photobucket page have a look through the pics or alternatively shoot him a PM.
I'm pretty sure he'll give you some good advice.
Good luck.
More pix on Flickr.
Man, that is a bad place to have rust. I would strip that thing down and see how bad the rest of the rust is. I would get it sand blasted by some one who has done old cars for some of the resto shops. If the entire top is rusted I might be looking for another CAB. You might could just get a top. or cut out a piece of a top like that.. If the floor, rockers, cab corners and the pillars are gone... I would be looking for a cab myself.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
I had mice build a nest there in my '56, and fixed rust such as by your thumb by using por-15 on the outside, cutting a hole inside the cab, taping the holes with masking tape on the outside, putting por-15 on the inside, then within 6 hrs using resto-grip filler (from the por-15 people) on the inside. Worked great initially, time will tell if the rust reappears. The hole your finger is in seems like a bigger kettle of fish. I second Michael's assessment if there are big holes. However, sand blasting may take out metal that may be saved with por-15 and fibreglas sheets.
Dave
Dave
Well, my time went so quickly,
I went lickety-splitly
Out to my ol' 55.
As I pulled away slowly,
Feelin' so holy,
God knows, I was feelin' alive..... Tom Waits, Ol' 55
LMCtruck now makes that replacement panel...like micheal64 said,if the rest of the cab is not too far gone,it's up to the indviduals welding skills,patience and of course money!...mark
