| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I have my wiring all done but I have a small draw on my battery that I can't seem to locate. This is how I did the Alternator Wiring Diagram Did I do something wrong here? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Fried,
If you have a voltmeter make sure that DA#1 has zero voltage when the key if OFF.
How do you know there is a drain on the battery? Is it discharging or have you found a draw with your meter? Killing individual circuits by pulling fuses can isolate a circuit and narrow your search.
I believe some modern electronic gadgets like digital clocks or CD players may draw a tiny amount when energized...could this be what you're seeing.
A bum alternator can discharge the battery too.
Stuart | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I took the ALT to the parts store and it checked out very good. I will double check the #1 (field) for zero with ignition off. I am showing an approximate 1.4 volt draw and I see a light spark when putting on the battery terminals. There are no accessory gadgets installed yet, just lights and gauges and an electric cooling fan. | | |
