2 members (delky, Steelonsteel),
235
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Is anyone out there running a stock 235 with 3.38 gears??
I’m seriously considering a change to a 3.38 ring and pinion to reduce RPM’s at highway speeds of 50 to 60 MPH. My truck currently has a 3.90 rear and I just don’t feel comfortable running for long distances above 2500 RPM. What worries me is how well it will pull away from a stop. I’m currently able to start very easily using my 3.478 to 1 second gear. What I’m hoping is not to have to use the 7.06 to 1 first gear after changing to a 3.38 ring and pinion.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think you will be ok getting started from a standing start. My concern would be high gear. You would be sacrificing quite a bit of performance. It doesn't hurt to run a 235 over 2500 rpm. They get pretty noisy at highway speed, but it doesn't hurt them. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That 235 if it's running right has plenty of torque for the 3.38 gears. I would go for it. It will make a whole new truck out of it. You will want to drive it a lot more. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | My Dad has a '59 1/2 ton with 235/3.90 and 3 speed and it is a pleasure to drive. It is driven at 60 plus mph regularly, and quite comfortably. He also used to have a '55 1/2 ton with 265 v8 and 3.38 gears and I thought it seemed a little sluggish compared to the '59.
Maybe you should consider an overdrive for the best of both worlds. | | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | Kip,
Have a 58 with a 235 and 2 years ago converted from the 3.90 to a 3.38. A little more finesse is needed when starting from a dead stop with the stock transmission, and you will need that first gear, but it has made it a real pleasure to drive. I have had it at 70 with no issues, but surprisingly, I thought there would be a notable increase in gas mileage. As most of my driving is in town, I have noticed only about a 2MPG increase.
I really do recommend the change, but expect to use first gear regularly.
Richard 58 3104
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thankx for all the help here. I just purchased a 3.38 set today. From Patrick’s, a nicer group of people you will not find !! | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I have now taken several drives with the truck’s new 3.38 gears. I couldn’t be happier. The ’53 Power Glide 235 which produced 115 HP new still has plenty of power to pull the 3.38. I’m using the ‘41’s original, granny geared, 4 spd. crash box and have absolutely no problem pulling away from a stop in 2nd gear. With my relatively small (almost stock) 205/78-15 tires I get about 24 MPH/ 1000RPM’s | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | From Patrick’s, a nicer group of people you will not find !! Kip, I agree with you on this! Those folks know what customer service is! | | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | Kip,
Glad that worked out so well. The 3.38 gearing really made mine much more enjoyable to drive.
Richard 58 3104
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I think a 3.38 is a bit much and Richard in Fl. doesn't have hills to deal with. I hope you don't up there cause I know it would not work for me because of the mountains I live in.
But you already have the gear, so let us know how it runs out after you swap gears. Thanks Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Well Dan, you are correct about hills, we don’t have many in Michigan and certainly not mountains like those west of you. So far no problem around here and if I do there is always 3rd gear. | | | | | Joined: May 2009 Posts: 13 New Guy | | New Guy Joined: May 2009 Posts: 13 | I live in Reno, Nv. and own prop near Sacramento, Ca. I have a 55 1st 3100 with the 235 and the 3:38 gear set. I run it regularly back and forth on I80 between Sac and back. Reno is 4000 ft elevation and Sac is less than 1000 feet. Donner Summit is 7200 feet. I have no problem running back and forth. there is a 7 mile stretch between Truckee, Ca. and the Donner Summit that goes from about 6000 ft. to 7200 ft., and unless I have a load on the truck, I have no problem pulling that hill. Get into the hills all around the area and just love driving my truck. Have fun. Bruce jr. | | | | | Joined: May 2009 Posts: 13 New Guy | | New Guy Joined: May 2009 Posts: 13 | P.S. Patrick has always been great when I have dealt with them. Great People and great service. | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I run a 261 with 3.50 gears and an overdrive transmission (GM 89mm). At 65mph it runs 2000 rpm. I have NO issues pulling hills, and if a hill comes up there is always 3rd gear (1:1).
I get 20 mpg on the highway. | | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | My truck has a 261 with TBI, T5 with .82 overdive and 3.08 rear end. I like it. It has plenty of power to pull it. You can allways drop drown a gear if needed, no big deal to down shift. | | |
