0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59410 04/19/2006 8:33 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Hello,
I am getting ready to install my Glass Bowl fuel filter on my 216.
I'm pretty sure that it's going to have to go on the line between the carburetor and the 90° bend where it goes over the block, but the horn and the vacuum line are in rather inconvenient places.
The Vacuum line shouldn't be too much of a problem to adjust, but the horn might be interesting. So far, I am thinking that it will have to go next to the horn trumpet.
Does anyone have a pic of how (and where) you mounted yours? Any other advice?
Thanks in advance, Brendan | | |
#59411 04/19/2006 9:18 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#59412 04/19/2006 10:38 PM | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Thats good information. I would like to do the same, but I have a carter yf and a standard "straight up" horn bracket. I think the horn bracket is the key part for this filter bowl installation. I'm looking for one as we speak.
1941 AK named "PETEY" my buddy.
#59413 04/20/2006 12:57 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | The intake manifold on a 235 with a Rochester must be positioned differently than with a 216 and a W-1. Either that, or the Rochester is just that much smaller.
The way that's set up isn't gonna fit with the horn where it is on my engine. There'll be no room to connect the line into the filter.
I do have some extra tubing scraps laying around... I could bend an oddball 90° piece and put the filter behind the horn that way.
Does the filter have to be right on the carb? | | |
#59414 04/20/2006 5:07 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | The filter was a part of the fuel pump. Kinda odd because the bowl is on top instead of the bottom. Check the service manual. | | |
#59415 04/20/2006 5:17 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Beaver 53: The filter was a part of the fuel pump. Kinda odd because the bowl is on top instead of the bottom. Check the service manual. No, the filter was an option. At least, it was back in 1946. The bowl filters strongly resemble the fuel pumps, so I can understand your confusion. Fuel Pump Fuel Filter | | |
#59416 04/20/2006 6:06 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I don't know if it's an original setup, but this is how I rigged my fuel filter. I have a 216 with a W-1 carb and a glass bowl filter too. Here. | | |
#59417 04/20/2006 11:05 AM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Originally posted by steppenwood: I don't know if it's an original setup, but this is how I rigged my fuel filter. I have a 216 with a W-1 carb and a glass bowl filter too. Here. I have the exact same setup as steppenwood's on my '51. | | |
#59418 04/20/2006 7:44 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Thanks guys. That's how I was thinking I was gonna have to pull this off. Looks like I'm going to be rebending some conduit...  | | |
#59419 04/20/2006 10:13 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | My 39 216 has the filter bowl on top and as a part of the fuel pump. i have seen these filter bowls that go inline. both before the pump and after. just so they are tight. i would recomend after the pump. any place in the fuel line. away from hot stuff.
"It ain't a truck if you can't hose out the cab."
#59420 04/20/2006 11:59 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I would NOT place it close to or above the exhaust header in case it (usually a cork gasket) leaks; vibrates loose; rattles open; or cracks !!
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#59421 04/28/2006 3:51 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Thanks for your input, everyone! It was very helpful.
I got the filter installed tonight (after some botched attempts at bending steel tubing) and she's out in the garage running right now! | | |
