2 members (Charles in CA, TexasJim50), 109 guests, and 5 robots.
Topics128,094
Posts1,056,058
Members48,433
Hello,
I'm converting my 48 to 12 volts. The alternator that I have has a pulley which is too skonny, I am hoping that I can use the pulley from my generator. The generator pulley came off easy. The nut holding the pulley on the alternator will not break loose. I am using a long 15/16" Craftsman wrench on the nut and an allen key with a 16" cheater bar to hold the shaft. Should I use heat? or impact?\
Chris
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Forget the wrench & the allen key & use an air impact on the nut. It'll come right off.................Joe
Don't even think of using the generator pulley unless it's the same diameter as the alternator pulley. If you slow the alternator rotor down with a big pulley, it won't charge at idle speed. Alternators need to turn at least 2 to 3 times crankshaft speed to be effective.
Jim Carter sells the pulley to convert to wider belt I got one and it bolts right on to Your alt. and is small so the alt. works right .
Part# HP530 pulley pg. 54 of 47-54 cat.
Pete
