3 members (78buckshot, klhansen, 1 invisible),
152
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello, I'm converting my 48 to 12 volts. The alternator that I have has a pulley which is too skonny, I am hoping that I can use the pulley from my generator. The generator pulley came off easy. The nut holding the pulley on the alternator will not break loose. I am using a long 15/16" Craftsman wrench on the nut and an allen key with a 16" cheater bar to hold the shaft. Should I use heat? or impact?\ Thanks, Chris | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Forget the wrench & the allen key & use an air impact on the nut. It'll come right off.................Joe | | | | | Joined: Feb 2004 Posts: 29,783 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,783 | Don't even think of using the generator pulley unless it's the same diameter as the alternator pulley. If you slow the alternator rotor down with a big pulley, it won't charge at idle speed. Alternators need to turn at least 2 to 3 times crankshaft speed to be effective. Jerry
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Jim Carter sells the pulley to convert to wider belt I got one and it bolts right on to Your alt. and is small so the alt. works right . Part# HP530 pulley pg. 54 of 47-54 cat.
Pete
