5 members (bobfake, MNSmith, Wayne67vert, Bill Hanlon, Hotrod Lincoln), 70 guests, and 1 robot.
Topics128,091
Posts1,056,036
Members48,433
Hello,
I'm converting my 48 to 12 volts. The alternator that I have has a pulley which is too skonny, I am hoping that I can use the pulley from my generator. The generator pulley came off easy. The nut holding the pulley on the alternator will not break loose. I am using a long 15/16" Craftsman wrench on the nut and an allen key with a 16" cheater bar to hold the shaft. Should I use heat? or impact?\
Chris
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Forget the wrench & the allen key & use an air impact on the nut. It'll come right off.................Joe
H Online: Content
Don't even think of using the generator pulley unless it's the same diameter as the alternator pulley. If you slow the alternator rotor down with a big pulley, it won't charge at idle speed. Alternators need to turn at least 2 to 3 times crankshaft speed to be effective.
Jim Carter sells the pulley to convert to wider belt I got one and it bolts right on to Your alt. and is small so the alt. works right .
Part# HP530 pulley pg. 54 of 47-54 cat.
Pete
