| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59371 04/18/2006 9:50 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Have a 58-62 235 head (3835913) which has the temp sensor opening on the rear driver's side. Want to block this opening as my truck has the GMC thermostat housing where the temp sensor is located. Assumed that the thread size of the head opening was 1/2" NPT. However, neither a 1/2" iron plumbing plug nor a brass plug fit in the opening. Threads are clean and not burred. Has anyone had this come up before? Are the threads in the female opening in the head tapered or straight? Thanks in advance. | | |
#59372 04/18/2006 11:38 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That's not the correct casting number for a '58-62 head, which does have 1/2" NPT threads. An earlier 235 head may have a 216 style thermometer opening which is like a 3/8" female gas tubing flare. It does not use pipe taper threads, they are straight cut. You may not have an easy time finding a plug for this, although you could use an adapter to go to 1/2" NPT and then plug it.
#59373 04/19/2006 4:29 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You may need to cut the bulb and fitting off a mechanical gauge to use as a plug.
See the USA in your vintage Chevrolet! My Blog | | |
#59374 04/19/2006 5:02 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Sorry, was thinking about the block casting number dates. Head is a 54-55. Think that I could use a regular straight cut bolt trimmed to fit in length with a compression washer under it? The bulb/fitting gauge combo was in there originally I believe, before it went to the machine shop. | | |
#59375 04/19/2006 5:22 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I think you could use a set screw and believe they come in that size and thread.
Check with a machine shop that does engine work, they use them to plug openings in the block just like the one in the head.
#59376 04/19/2006 5:23 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | PS-
Pipe dope or Permatex 2 on the threads-
#59377 04/19/2006 6:53 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | In my area, Carquest has by far the best selection of plugs.
Mike Barnes 1950 GMC 1-ton pickup
#59378 04/19/2006 8:42 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Thanks! Went to Lowe's and bought a 1/2" flare plug which appears to have straight threads on it. Lowe's has those "try it" bolt and nut racks where you can check your thread sizes. Tried a NPT fitting in the flare female spot and it caught after a thread or two just like what it does on my head. Tried the flare plug in the NPT female spot and it was just the slightest bit loose but went in cleanly. Think it may work. Will try tomorrow and will post the result. | | |
#59379 04/21/2006 9:58 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | F***ing fitting didn't work. Back to the drawing board. | | |
#59380 04/22/2006 2:07 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You could also tap it to pipe thread and plug it.
#59381 04/22/2006 1:34 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Think that's exactly what I'm going to do Dave. | | |
#59382 04/22/2006 8:11 PM | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | For what it is worth, I have sealed threaded holes in pressurized live steam pipes by wrapping a loosely fitting fitting with a lot of teflon pipe tape. It works if the fitting is not too loose. It is not an elegant solution, but works. Jimmie | | |
#59383 04/28/2006 11:27 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Finally got this one figured out. Size is 5/8" 18 tpi. Straight thread. Neighbor Hank, machined one for me out of brass stock. Fits perfectly. Look at the miscellaneous album for the pics. Hank says he'll make these for a price! http://community.webshots.com/user/geezer | | |
#59384 04/29/2006 1:15 PM | Joined: Jan 2006 Posts: 21 Junior Member | | Junior Member Joined: Jan 2006 Posts: 21 | Interestin story and fix
Taco
