3 members (Lightholder's Dad, Charles in CA, Philipj), 63 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
I am hoping this is the right section for my question...I really couldn't find anywhere better.
I really like the look spot lights give a truck; however, was this an option offered back in '51 or a trend that has come thru the years?
What would be the right period (make and model) of a spot light if I shall install one in my truck? Are these left and right units or one will work both sides?
Thank you in advance
Bill Burmeister
Any models you can suggest?
Here's the application guide. That one is for the 5". Just plug in the year and make, pulls up the part numbers. There's also listings for 12 volt for the AD cab, too.
Bill Burmeister
If you decide to install a spot light, check that there is not wire harness that passes inside the windshield frame. If there is, you have to hold it out of the way when drilling for the light. I don't remember if the trucks have that harness, but the older passenger cars have one for the rear lights. Quite a few of those harnesses got drilled when installing spot lights on those passenger cars.
Harvester
Heres a shot of the Unity 6" spot installed on a 51 1 ton.
Tried a 5" but it looked kinda wimpy on tis big truck.
Didn't encounter any wires when drilling the post,but the dome light wire might be there,so proceed with caution!
http://thumb15.webshots.net/t/52/552/4/69/84/2212469840103393295UNpAxq_th.jpg
That picture looks great that's the look I am going for...I guess is off to finding me some spot lights.
