9 members (Peggy M, JoeDude, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, Stovebolt48, Donf, 1 invisible),
93
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 3 New Guy | | New Guy Joined: Nov 2009 Posts: 3 | i have a 1965 chevy truck. the vin # i have for my truck is:cl545j128417 but the truck is a 2wd shortbed. i would like to decode this, any help would be very appreciated. | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I think this is some of the info you want...
c l5 4 5 j 128417
C = 2 wheel drive 15 = 1/2 ton long bed 127 wheelbase 4 = Pickup 5 = year=1965 j = assembly plant = J = Janesville
128417 = s. number
You can get this info just about anywhere. This is what I got out of the fist couple of pages of my LMC catalog.
I hope this is what you wanted and what you were looking for.. God Bless...
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Nov 2009 Posts: 3 New Guy | | New Guy Joined: Nov 2009 Posts: 3 | I AM SORRY ABOUT THE SERIAL NUMBER IT IS: CL545J128417. MY TRUCK IS A 2WD SHORTBED. THERE WAS NO BED ON THIS TRUCK WHEN I BOUGHT IT SO I DONT KNOW WHAT TYPE OF BED IT HAD ON IT. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I double checked the code in my source book, I come up with the same information as Micheal. I'm going to venture a guess, and say thit your truck may not have the original cab on it. I'm not sure if they still stamped the serial number on the chassis on the '60 and later trucks like they did with the '55-'59s, but it may be worth looking to see if it has one on it. Unfortunatly, the serial number will not tell you what bed the truck originally had.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 3 New Guy | | New Guy Joined: Nov 2009 Posts: 3 | i did not see a serial number tag on the cab of the truck ,but i do have the title to the truck. i did not know about the serial number on the frame thanks. i will check the # on the frame. | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | There should be a metal tag at the top of the inner door opening on the driver's side . At least , there is on my '65 C10 .There are also numbers on the top of the frame just forward of the motor mount on the driver's side .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
